I am struggling to remove cowl because the rear lock won’t budge. Any suggestions
2016 f series 115hp cowl removal
Maybe try having someone press down on the back of the cowling as you try and turn the lock.
Maybe loosen the front clamp to see if the front of the cowl can move upward and in so doing relieve any excess load there may be on the aft clamp mechanism.Last edited by boscoe99; 04-20-2019, 09:08 PM.
Originally posted by 99yam40 View Postman a 2 or 3 year old motor and it rusted up already.
possible water leak inside .
only thing I can think of is drilling.
but will need to find the correct place to drill
The front latch is perfect. I can lift the cowl 6 inches in the front so have been pouring penetrating oil onto the shaft. No sign of water or corrosion in side at all
I ended up freeing up the cowl handle. I released the front and pushed it up as high as I could. I then used a 1/4” socket wrench with a 12mm and a really good flashlight. Removed the bolt holding the latch and removed the cowl. Much easier to free up the shaft then. The socket wrench was a multi angle 12 “ which made life easy
Originally posted by Adekpnin View PostI ended up freeing up the cowl handle. I released the front and pushed it up as high as I could. I then used a 1/4” socket wrench with a 12mm and a really good flashlight. Removed the bolt holding the latch and removed the cowl. Much easier to free up the shaft then. The socket wrench was a multi angle 12 “ which made life easy
Defective?Scott
It's a great rule to follow: if it moves Then oil or grease regularly, especially around saltwater environment....
ÂÂÂÂÂÂÂÂ
