Is anybody having as much trouble with injectors as me. I have had them cleaned once and replaced once in the last four years. Now today I seem to be having the same problem.My motor is a 2001 F115txrz. I would like to hear from anybodys cures and problems.Kyle roberts
dirty injestors
Been there done that. Bought a second set for my F115. so I could send one set out to be cleaned.
I send mine to: SouthBay Fuel Injectors
They have done a great job in the past. The problenm is the ethanol in the fuel.
Ethanol and Methanol are corrosive, hygroscopic (like water) and older motors were not designed to accomodate it Methanol and ethanol are great racing fuels and belong at the track not on the water.
Best you can do is clean out your fuel system, add filters and run your motor completely out of gas before you winterize.
FYI the injectors are easy to replace if you have second set. Check you tube there are videos that will show you howw to do it. Easier than changing plugs on an F 115
ÂÂÂÂÂÂÂÂÂÂ
