I have a 1998 C90 2 stroke that cylinder #3 is only running at higher speeds and takes quite awhile to start firing. When I drop back it quits again. I have changed plugs and swapped coil packs and the problem remains in cyl 3 Any ideas. Thanks
Cylinder intermittent
Originally posted by Riddler360 View PostI have a 1998 C90 2 stroke that cylinder #3 is only running at higher speeds and takes quite awhile to start firing. When I drop back it quits again. I have changed plugs and swapped coil packs and the problem remains in cyl 3 Any ideas. Thanks
I'd pull the carb, carb bowl and check for any varnish. While there, pull the main and idle jets and check to make sure their clear.
Sounds like your getting fuel thru the main (high RPM's) but at idle, that jet is plugged up and no fuel is getting to the cylinder.Last edited by TownsendsFJR1300; 06-29-2014, 05:31 PM.Scott
Originally posted by 99yam40 View Post#3 is the one that furnishes the pulse for fuel pump, check to make sure it is not leaking fuel into the crank caseScott
ÂÂÂ
