What is a good starting point(turns from seated postion) for the throttle stop screw on a 2003 yamaha 130 txrb
Throttle stop screw
Are you asking about (on your CARBED ENGINE), the throttle stop screw or the smaller air mixture screw?
Idle, warmed up, should be around 7-800 RPM's.
I think you are referring to the smaller air screw.
IDK but someone else will chime in, probably close to 1 turn outLast edited by TownsendsFJR1300; 06-26-2014, 06:03 PM.Scott
The throttle stop screw not pilot screw. I messed with that screw and now I think I shouldn't. Looking at the manual it says the screw is for sync the carbs and setting idle speed. When I went to start engine after messing with it trying to lower my idle speed it wouldn't start after that. In the manual it says the that throttle cam should be lined up with the throttle roller. Should they be touching? Also where is a good starting point to start with the throttle stop screw? Thanks
Generally you back the main IDLE screw out so the ALL the THROTTLE PLATES close fully. The rod that goes inbetween the two carbs(linking them together) is now adjusted (synced), so the throttle plates open the same amount.
On my F150, there is .020" space at part of the linkage but your engine will MOST likely be different.
**As you posted above, per your manual, they should line up. Mine does as well. The manual should give you a clearance # or have it touch (I don't know specifically about your engine spec's) but mine calls for .020" space there, in the second pic ..
Yours may very well be different, your shop manual should address the linkage adjustment.
Once those are set, adjust the main idle(with spring around it) screw back in to get the correct idle RPM's..Last edited by TownsendsFJR1300; 06-27-2014, 08:31 AM.Scott
ÂÂÂ
