Today I replaced the thermostat and the PCV valve on the engine. When I crank it up at the dock the cylinder head cover gets pretty hot. Is that normal for idle? The outer exhaust cover was cool to the touch.
80HP Yamaha 2-Stroke Overheating Issue
Originally posted by fishfun83 View PostToday I replaced the thermostat and the PCV valve on the engine. When I crank it up at the dock the cylinder head cover gets pretty hot. Is that normal for idle? The outer exhaust cover was cool to the touch.
How much salt was found?Scott
If water is NOT FLOWING TO that area DUE TO A RESTRICTION it will get hot..
I think it appropriate again to point out the pee stream limitation. It just shows your pump working and not that it is circulating through all of the engine.
A strong stream fools the mind to believing this. In fact a strong stream can result from a blockage upstream, and not indicate a weakening pump even. Don't know why not a better design; fools a lot of people.
looks like that stat was not even closing properly.
without real temp numbers, how is someone suppose to even guess what is going on.
Did you try to flush the system out like I said?
or did you just replace those parts?
You did say it looked like mud, so that should be able to be flushed out with water and compressed airLast edited by 99yam40; 04-09-2019, 08:33 PM.
Originally posted by 99yam40 View Postlooks like that stat was not even closing properly.
Agreed with all that "mud" in there to pull the stat again full with a bunch of water, etc, (WAY BEFORE pulling the head)..
If you can get a pressure washer wand to reach INTO the cylinder area, that might work better (if the muck doesn't flush out easily)
Seems "muck" prevents / hampers salt erosion!!
I would open up the exhaust cover and have a look at the bigger powerhead fill holes in the chamber to the right of the exhaust line shown in the pic.
Originally posted by 99yam40 View PostI have stopped =my brothers C60 from overheating at high RPM by dropping the lower unit, pulling the statcover and stat, hooked up a water hose directly to the water tube heading to power head, turning water wide open letting it flow out everywhere it can, and then shooting compressed air into the water hose off and on .( I just poked a hole in the hose with my small nossel on my air gun, but maybe set up a tee and some valves would work)
lots of stuff came out.
the air and water helps move things around and out.
We ran it up and down the river for 30 minutes with no overheating.
Something to try if you do not want to take it apart right away
ÂÂÂÂÂÂÂ
