I couldn't find a topic exactly like this one and I'm stumped on my issue summarized below.
Running normally buzzer sounds, open engine, see low oil, remote tank nearly full, emergency switch oil transfers up to top. Restarted engine fine rest of the day but I didn't go far enough to auto fill again.
Back at slip, I did some testing. My tach has the 3 led display with red, yellow, green items for oil. When i key on all three arrows flash, it goes green for 5-10 seconds then yellow. This means remote tank is low, but it's not. Explains why it is not auto filling remote tank. I dismantled remote tank fill switch and cleaned it. Slides freely and tested with multimeter. Continuity when in tank. Tested blk and black/red wire at engine entrance where it plugs to first harness and same continuity. Also jumped matching wires on female engine side and tach stays on yellow light.
I can't find where blk/red wire goes further upstream.
Also the pump doesn't run when i turn the key on. I'm pretty sure it used to for 10 sec or so
My question is this
Could the tach be in error? Red/buzzer seems to work fine, but i never paid attention to it before. I'm sure oil transfer worked last season.
Where does tach get signal from? The oil control module with the emergency switch?
Is that module the problem? I hate to spend $250 and find it is something else. Any ideas what else it could be?
Is that a plug and play part with no tuning?
Also my trim sensor works fine and shows full down. Should not be related but i see many people saying to check this.
My question is this
