I have a pair of 1988 150's in which I am getting an overheat alarm at 4000+ RPM that I can't solve. Here is what I have done to the motors:
1) replaced impeller, base plate, cap and all gaskets in March and everything had been running fine until May. Went to the Keys and got the boat up to 4200 RPM on two occasions and it went into limp mode both times.
2) I changed all 4 thermostats and gaskets ( one was hung wide open, the rest work as they should) while I had them out I left the thermostats out of the right head and started the motors to check waterflow. Both motors had water pouring out of the thermostat hole.
3) I changed poppet valve spring and grommet, new poppet won't be in until Wednesday( one was hung in grommet pretty tight, Had to use pliers to pull it loose but grommet and spring are now new)
4) removed and cleaned all 4 temp sensors, Placed in hot water on multi meter for continuity and all 4 passed, reinstalled into motors
Ran boat today same condition presented itself. I unplugged all 4 temp sensors and boat ran flawlessly. Plugged in starboard motor temp sensors and alarm went off when over 4000 rpm. I verified it was the right head by unplugging both while alarm was going off. I then switched temp sensors and ran up to speed again. Right head temp sensor went off again
5) port motor alarm went off but as soon as I put motors in Neutral it stopped which it hasn't done before so I am wondering if the motors are somehow linked thru the key switches causing the port motor alarm to go off when there may not be a problem. I was not able to check head temp sensor on port motor since alarm would quit as soon as I pulled throttles back into neutral.
Here is the real rub. when this condition presents itself I have a stream of water peeing from the outlet and it is warm as it should be. I can touch all 4 heads when the condition happens and leave my hands on the heads and thermostat covers without burning myself. I am at a loss. Any ideas on anything I may have missed or is it time to pull the heads and head covers???
Any help will be much more than appreciated.
