40 hp won't start cold
  • 40 hp won't start cold
    I have a 1999 40 horse 2 cycle that won't start cold unless you use the emergency start lever, then it starts fine for the rest of the day. I have power to the prime start assy when cranking and took the assy off and applied direct 12v to it and nothing happens. Is it supposed to act like a solenoid and open or close when power applied? Any help would be greatly appreciated
    see if this thread helps you understand the system better
    http://www.yamahaoutboardparts.com/f...n-th11452.html
    Depends on how you are trying to start the motor when cold
    pump primer bulb until firm, just turn the key for a few seconds without opening fast idle lever, , and repeat the turn of key if needed.
    Should start with 2 or 3 3-5 second turns of key.
    If not there is something plugging up the passages in prime start system
