Got this motor for my inflatable. Obviously used. saw it was leaking out of the little hole pictured. Anyone know what could be causing it,and how to fix it?
Is oil supposed to cone out here?
Looking at your picture the oil looks green, very much like two stroke engine oil (the oil added to fuel). You can check this by smelling it. Proper gear oil is quite strong smelling.
And those holes bleed water out of hollows in the castings.
I guess, it is oil coming from above inside the cowling from spillage/ leakage. Even if the gear box was incorrectly filled with two stroke engine oil, it is very unlikely that that oil came out of the lower unit through those holes.
That's not to say it isn't a good idea to test the sealing of the unit. If you see milky oil coming out when you drain it, you probably should embark on changing seals eventually.
At this stage methinks that oil didn't come from the lower unit. Check inside the engine cowling too.
Could be Merc Hi-Performance gear lube - the color looks about right.
Does this engine even use an oil injected system, or is it pre-mix?
In addition to smelling - and comparing to the 2 cycle oil you use if you have an oil injected sytem - you can compare the color to the gear lube in the case by leaking a few drops out.
Gear lube seems to make the most sense, I think.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
if you look at the tag the C says it is commercial. single carb non oil injected 2 stroke 25.
typically if yoi did not burn the premix and the raw oil/fuel mix goes down the leg it dissolves the carbon and dripps out black.
not clear.
typically oil from that hole is a shift shaft seal leak.
My C40TLRX did have the lower crank seal leaking I guess, and some of the recirculating check valves bad when I took it apart to replace the crank due to bad bearings and it had clean 2 stroke oil running down the drive shaft lubing the water pump impeller.
I think it did have some clean oil come out of the drain holes too.
but cannot swear on that.
smell test will confirm.
lower gear oil and 2 stroke oil smell totally differentLast edited by 99yam40; 02-15-2019, 10:06 PM.
Â
