Tale Tail ?
  • Tale Tail ?
    2011 F150
    Should water come out the Tale Tail when the motor is cold when flushing with the hose connection? This is for a friend.
    When I've done mine on my F80 it's always warm and shoots a good stream.
    It may or it may not when being run on the hose.
    When in the water the tell tale should be available at all times.
    Temperature of the water from the tell tale means nothing.
    Different model Yams work in different ways.
      Not running it just hooking it to the hose connection (not muffs) and letting the water run.
      This is my boss's motor that he just had serviced
      New WP new stats and oil change
