nope.
some vehicles used a dual ballast,some used a heated ballast,some used a coil with an internal resistor AND a tap from the R terminal on the starter SOLINOID.
the reason is the ign coil only needed 7.5-9v to operate efficiently on a 12V system that at speed my be running 14.5.
if you don't need the heat electrical devices last longer cooler.
however for reliable cold starts we hit the primaries with battery voltage then drop it once the engine starts.
as far as point gap goes,you set the gap then check the dwell.
dwell is the important thing.
if the dwell is correct then the gap is correct.
I actually ran across my old dwell meter the other day,wondered would it still work.
don't know of any point types system to use it on..
last one I did was about 15 yrs ago on an old 153 CID mercruiser.
guy's dad owned the boat in the late 60's and he wanted it restored.
dunno what he spent on the hull and the interior but he spent over 8 grand with me.
