F200 won't throttle up when warm
  • F200 won't throttle up when warm
    I have a 2003 Yamaha F200 and have an issue regarding throttle once the engine has been running for about ½ hour. It will warm up and run for about 30 minutes, but if I stop and restart the engine or come back to an idle for some time I can no longer take it past about 3000 rpm or use any more than about ½ throttle – the engine labours and pulls back to about 2000 rpm and will only let me pull up past 3000 rpm very slowly over about 5 minutes.
    I recently had rusty water in the fuel, so I have already done the following:
    • Serviced all injectors and their baskets
    • Cleaned out entire fuel rail system of contamination (I have even pressure on both sides)
    • All filters/separators have been replaced
    • Flushed all fuel lines and primer bulb
    • New high pressure fuel pump (old one had rusted due to water in fuel)
    • Flushed fuel tank
    • New spark plugs
    I am lost as to what else it could be…any advise would be greatly appreciated!
    try again but this time when you restart it FIRST pump up the primer bulb.
    report the results.
      Will do...I assume you're thinking it could be the lift pump? It's the only part I've yet to replace.
        not suspecting the lift pump.
        possibly the relief valve.
        that's why I made the statement.
