99yam; I applied some mild loads. You can see the voltage drop. I am thinking that the regulator is doing this internally as needed to keep the output voltage at some specific value. Changing constantly as other loads in parallel with the R/R are changing.
More tests to be done at three other rotor speeds. Then with the Yamaha R/R connected.
