Works fine then it will not pick up and motor vibrates. Replaced gas. If left to cool down after an hour or so will again work fine.
yamaha 2003 70hp vibrates and wont plane out after working fine for 30 min.
gauges do not work
mechanic says it may be the power pack heating up.it will work fine until its on full throttle for awhile then it will only go slow, if I try to plane out the motor will shake violently. if it sits off for 45 minutes to an hour it will work again. can I use Freon to cool the power pack to troubleshoot to see if that's the problem
ÂÂ
