Using permanent magnets makes the generator free from slip rings, that presumably wearout at a greater rate than the bearings; a not completely free of moving parts system.
I think outboard electricity generation needs to change. At least from the heat point of view, flywheels can be made inverted with the magnets and coils mounted on the top instead of inside the flywheel. This however will require a frame over the flywheel, adding complexity and greater dimensions to an already large package.
As stated wasting horsepower by shunting off electricity is stupid. It is the problem from having large magnets. I can't see why you can't have a system whereby a PMG only supplies the "rotor" current, the rest of the alternator being regulated the more automobile conventional way. Yes more complex but surely more desirable than the outsized development of the permanent magnet generator causing huge heat generation and the waste of fuel and horsepower.
