I have never had to "mess with" the TPS on the 2006 F90 -
although aware from the SM of the "learning function" design
so i followed the recent threads with interest,
particularly the attempts to "interpret" the SM verbiage.
I took some some today to get out YDS and the VOM and do some 'sperimenting.
"As found" at key on - backprobing the TPS output measured 0.909 with the VOM
and hooking up YDS showed almost exactly the same value:
OK - makes sense - the "actual" value was NMT 1.4 -
so the ECU used the "actual" value.
Next, I opened the throttle, to cause the TPS to output 1.547 V -
and then I turned key off.
I was expecting, when I turned it back on,
I would see YDS show 1.4 - while the VOM showed 1.547 -
Nope.
Not only did the ECU display the actual TPS voltage of 1.547
it also correctly indicated that the throttle was open to 21 degrees
So I have no idea what the "learning function" means.
Although here is one more interesting observation:
while I was standing there, staring at the YDS screen -
baffled that the ECU was actually correctly displaying TPS voltage
AND
that the throttle was actually open 21 degrees -
I idly moused over to do a "Stationary Test"
and got this:
Nope.
AND
and got this:
