Speedometer stopped working completely
  • Speedometer stopped working completely
    Good day all
    I have a 1996 Yamaha saltwater ser. My speedometer stoped working I mean nata yes it sits out side maybe athe sun got to it
    Is there anything I can do to check if it's completely cooked
    It's acting like no power
    Richard
    Most speedos i am familiar w are ran by water pressure, not voltage based, (unless they are GPS) trace the hose from speedo back and look for break
      some have a hole about 1/8 in lower unit that picks up water but they are not accurate, any wood, debri, or trash will stop up that hole and speedo will not work, I keep a small drill bit in my boat just for this issue, especially for winter fishing when that hole gets clogged water is trapped in that section of lower unit, the hole is on the lower unit and in the v section of the motor below cavation plate and above prop
        I believe he is saying his digital speedo gauge is not coming on.
        Check for voltage to it
          Originally posted by Richardr55 View Post
          Good day all
          Richard
          If the display slowly faded out over time (not a quick, just stopped working) and eventually went blank, its likely just worn out.
          The visable alarms, (if any on your gauge at the bottom) do usually still work (when you initially turn the key on) even if the main display is dead.
          If your(I don't think you are) seeing a 0 MPH, the pitot hole on the LU is likely clogged.
            Speed metor
            I have no power to it the way it's acting
            Digital not working at all
            Richard
              Not at all
                Richard
                Then measure to see if there is voltage to it or not, we sure cannot do it from this side of computer
