I have a question and I would like to get some input on my problem. I have a 1992 Yamaha Pro 60 tiller. Every once in a while, I will tilt the motor up and ever so very slowly it will lower down. Any ideas on what the problem and possible solution(s) might be. Thanks in advance.
Slow drop on 1992 Pro 60
you definatly have an issue.
reason I asked is I recently had one in the shop with a "leak down" issue.
seems it would drop about 2" over about 1 month.
kinda normal sometimes.
things to look for on yours
up main valve
up relief valve
manual release valve
trim piston orings
free piston orings
ÂÂÂÂÂ
