Hey i will be using Yamaha Ring Free Plus for the first time on my Yamaha F225 4 stroke. My engine has roughly 500 hours. I usually only use Sta Bil 360. I would like to try and clean my fuel system, injectors etc. I will be adding it directly to my gas tank like i do with the Sta Bil. Is there anything I should know or be aware of ? Ive hear that it can clog the filters if you haven't used it in the past. Thanks.
Ring Free Plus First Time ?
If I haven’t ever used ring free plus for the first 500 hours can I just begin adding it to my fuel along with the sta bil ?
I see no reason Ringfree would plug filters unless you tank and lines have a lot of crud built up in them , and then ring free may clean that off sending it on down stream to the filters
FWIW, seem I have read Yamaha prose that suggests - for a four stroke -
changing the engine oil and filter after a first time "shock use" of Ring Free
the premise, apparently,
that so much combustion chamber carbon is "washed loose" into the oil
all motor cleaners I have read about recommend changing the oil and filter after a shock treatment along with the plugs.
I would think even if the carbon does not get into the oil some of the cleaner will
ÂÂÂÂÂÂÂ
