hello and thanks for any responses. I bought a sailboat with a 9.9 ELHT motor. No water flow through the tell tale. I used the impeller kit and replaced all parts. Still no water at tell tale. Blew air through the system on both sides of the thermostat. I removed the thermostat. Air went through the engine fine but very slow through the water tube from lower unit attachment. Could there be some kind of clog in the space where the tube attaches? The tube is clear I removed it to check. So to check if the impeller is working which way should I turn the drive shaft?
Thanks again for any help.
