Changing timing belts on my F300s (made late 2013) for first time, and no expert. A couple questions:
1. Does it matter which direction the crankshaft is moved (clockwise or counterclockwise as viewed from above) before removal to line up the marks for the timing belt? Same for both port and starboard engines I assume?
2. What is best way to move the crankshaft to align the marks? Can't budge by hand, and no bolt on crankshaft.
Thanks.
Thanks.
