Engine runs great when computer bypassed, but how long can it run like that? Does anyone repair the micro computers on these engines?
1988 220 micro computer
may not be the computer.
in bypass spark is still generated by the charge coils and cdi.
iys con*****ed by the fixed pulser coils.
you should note an increased idle speed as ign timing is now fixed at 7*BTDC.
top speed cannot be reached as timing is fixed.
the computer modifies base fixed timing based on various input signals.
no place I ever heard of to test the computer.
I have never seen one fail personally.
however I have only been doing this type work for a living for only 30 or so years.
I have seen knock sensors fail, ground and 12V feeds fail.
TPS fail, pulser coils fail and such whatnots.
ALL the computer did on that model,for ign, was MODIFY the base ign timing curve.
myself I would carefully test the inputs as that computer is rather expensive new and hasn't been used in about 25 years.
kinda like your 25 yr old car or TV.
Â
