2001 F80 with 700 hours. Ran for a bit, shut it down, then wouldnt restart. Got it off the water, pulled spark plugs, checked comp. 30psi top, zero (or close to it) across the other 3. Plugs look fine. Timing belt missing some chunks out of a few teeth. Anyone have any experience with a similar scenario that can elaborate on the outcome? New here but not to stuff that floats.
F80 Jumped Time?
Believe this is a non-clearance motor. I gave the hairy eyeball downrange and didnt see marks on the pistons, but those plug holes are deep and I dont have a borescope (yet). I just want to make a good decision on repairs before going that route.
why not simply rotate the crank and see if all the timing marks on the flywheel and cam sprockets are still aligned?
that will tell you if it jumped time.
its also why Yamaha recommends belt replacement at 500 hours OR 5 years whichever occurs FIRST.
I wasnt clear; it has jumped time. I was wondering if anyone has experience with a similar failure and could ellaborate on costs, etc. Its a new to me non-runner motor. note- tensioner loosened in this photo.Attached Files
Can someone tell me where the 5 year t/belt replacement interval is documented?Attached Files
See the maintenance schedule in this owner's manual.
Owners Manuals | Yamaha Outboards
I recall it being five years or one thousand hours. Five hundred hours would be more conservative still. But in your case the drive belt should have been changed several times by now, at five year intervals.
It is a tough lesson. But as the man says, pay me some money now or pay me a lot more later.
See note three on page 4-9.
An owner's manual and a service manual take precedence over any generic, non-specific document such as the Yamaha MTG by the way.Last edited by boscoe99; 05-02-2014, 07:35 PM.
I still dont see any documentation on the 5 year replacement interval mentioned. EDIT FOUND- Footnote 3 page 4-9
In any case, its no lesson for me, as I said its a new to me and I purchased it as non-runner engine. I am going to have it repaired or its parts. My original post was a query for experience with this failure. I came here to ask because you guys run these motors and many of you work on them as well.
At this point, should I install new t-belt and retest compression, and what should the comp # be? Or should I go directly to "pull the head"?
Belt pic attached.Attached FilesLast edited by MercerRec; 05-02-2014, 06:42 PM.
yea its a hard lesson.
its also why when purchashing an older motor simply assume the last owner neglected ALL maint.
they typically do.
I actually have records of customers stuff stretching back to 1989 or so.
I am currently selling a boat for a friends widow that I installed the motor in 1998.
I have records of any and all maint actions from 1998.
its a 25' sou'wester with a 260 hp Volvo with an SX drive if anyone is interested.
but unless otherwise documented ALWAYS do the rubber parts and fuel system maint on ANY used purchase.
