The motor was running great except after I idled for about 15-20 minutes then go to take off it would stall. Other than that it ran great. I decided I'd take the carbs off and clean them which I thought went well I completely gutted each carb soaked the jets and bowl in carb cleaner etc. After reassembly I can't get the motor to crank! Any ideas on what I screwed up? I notice when I pump the bulb and squeeze it tight I don't here the gas getting forced through the carbs like before. Any ideas?? Thanks in advance!
2004 Yamaha 50 2-stroke Help
[QUOTE=Yamaha Outboard Motor[/QUOTE]
You've been reported BTW....Last edited by TownsendsFJR1300; 05-09-2014, 05:21 PM.Scott
Â
