I have removed the six bolts on the sides, the upper motor pin on the big ram, the pump motor on left and the reservoir on right and cannot figure out how to remove the assembly. There does not seem to be enough room to clear the unit from the motor mounts that surround it. The unit is a 6H1-15. I would hope the motor does not have to be removed to get this unit out.
