1993 Yamaha L200TXRR wiring issue
  • 1993 Yamaha L200TXRR wiring issue
    Good morning folks,
    I recently was correcting some improper wiring with my outboard motor and got most of it fixed. Two issues still remain;
    1) The pink wire that goes up to the remote start panel was (I think incorrectly) hooked up to a 12V power wire with a 30amp fuse. I removed the attachment to the power wire and am wondering if it should go to the pink wires that go to the two temp sensors on the block.
    2) The yellow wire was just cut off in the main 10 wire harness going to the remote start panel. According to the wiring diagram, it is supposed to go to the CDI. There is a yellow terminal coming from the CDI, should I reattach it there? Any help would be greatly appreciated.
    Jon
