I have a 2005? F150TXRD, 63P X 1025540 N with a ECU 63P-30. It does have the white plug with the blue and white wires at the front of the engine. I have hooked up a Garmin 94sv with a NMEA 2000 starter kit, but I do not get any information other than some miscellaneous engine alarms like engine shut down, neutral switch, etc. but no tach or fuel readings. I am doing something wrong or is my engine not NMEA capable? Is there a solution to make it work?
Thanks!
Thanks!
