Was running full out about 5000 RPM when engine, the engine started to lose power, then stalled. Had intermittent battery issues all season, so charging and jumping has been the norm all summer. Upon restart noticed a rougher idle, and rougher run, with a slight knocking. Pulled plugs to check for any sign of piston, cylinder damage - A blown piston would hammer the plug and present aluminum residue, so I've been told. Did a compression test and 5/6 cylinders tested normal between 110/120 PSI with the exception of the lower port cylinder. This cylinder tested 30PSI - Ran the boat today at 4800 RPM and it ran fine with a slight noticeable loss of power. I'm thinking it's not piston/cylinder - but perhaps a ring.
Any thoughts??? Clearly a rebuild on this engine will probably not happen, but if it's ring job, might be feasible. Any thoughts?
