Broke off a drill bit in tube trying to clear it. I can not blow it back out from the upper joint connection. Is the backside in the gear shift chamber, not sure i want to tackle that???
lower unit speed pick up tube
Had a small bit mounted in a short wood dowel and cleaned port for years in the driveway that way with finger twisting. However, got in a hurry one day trying to do it hanging out over the back of boat in the water, well the rest is obvious..1991 Kingfisher 179. Yamaha ProV 150, P150TLRP,Ser#352453, code 6J9L, eng#038614. prop-SS. 25-M.
I'd disconnect the water hose(speedometer hose) at the front of the engine (should be a junction about 2' forward of the hood).
Either use some air pressure (air compressor) from the top, downwards and tap the LU (with air pressure) to help dislodge it.
If no air is available, slip a small funnel over the engine side of that hose. Take your garden hose nozzle and blow water from the top down, again tapping on the power unit. You may be able to dislodge it. GENTLY tapping the broken bit also with another bit may loosen it.
Good luckLast edited by TownsendsFJR1300; 03-31-2014, 05:49 PM.Scott
broke a bit off in mine about a year ago. Take some marine weld and cover your exsisting hole and about a quarter of a inch higher drill new one. Mine is working great again. I tried all of those things to try to get the bit out but nothing worked for me.
Originally posted by teebeau69 View Postbroke a bit off in mine about a year ago. Take some marine weld and cover your exsisting hole and about a quarter of a inch higher drill new one. Mine is working great again. I tried all of those things to try to get the bit out but nothing worked for me.
Somewhat related, when I was having issus with salt build up in that pitot tube, the Yamaha service manager stated they were CAREFULLY opening up that stock hole just a tad.Scott
Originally posted by Jerry Bailey View PostFinally. Tube is 5/32, my bit was 1\16. Tried everything, but was able to take a small wire that would work into the bits groove and pulled out the broken bit. Just lucky.Scott
ÂÂÂÂ
