Hi,
Got a 2006 Yamaha v150tlr Vmax outboard, if running above 4000rpm the overheat alarm goes on and rpm is cut to 2000rpm.
Have now replaced thermostats, waterpump, headgaskets, poppet valve, cleaned waterjackets heads etc. Still alarm comes on minutes after passing 4000rpm
Also installed a gauge on water pressure, pressure is ok.
thermoswitches open at 82 degrees.
anybody know what could be the problem?
