Has anyone in the Wilmington, NC area had any experience having some welding done on their powerhead to resurface the mating surfaces? I discovered that I had just enough corrosion around one side of the exhaust port on my powerhead to allow gasses to escape and allow water to run in to the exhaust tube.
Welding mating surface on Yamaha powerhead
The corrosion was not too bad, just enough to make a leak. This picture shows the line I made with a sharpie, but the corrosion was mostly on the curved part. I took a file and whittled it down to bare metal. I'll call around to the prop shops tomorrow. I got one possibility at a machine shop here locally/
Originally posted by Keith Ohanesian View PostCall Warren Racing Engines in Clinton 9105926724. If they can't do it they should know who can.
A mill would be real nice but as noted, ain't gonna happen...
Way back, I had a Yamaha MC engine with 1 of 4 main studs that hold the cylinder and head on, strip out and the edge of the block crack (1970 ATI 125cc).
We had the block / hole welded back up. (I was 15 or 16 at the time) and I spent many days with a file and flat edge filing and drilling/threading.
I suspect you'll be doing the same.
At least now a days, there's more tools to work with, dremels, etc.
Worked great after that, no leaks (no sealer either) and that sealed the lower end of the two stroke which has fuel/air being pushed thru it, (piston/port configuration)Scott
Originally posted by TownsendsFJR1300 View PostA mill would be real nice but as noted, ain't gonna happen...
I finally got to filing the power head down and it was not as hard as I had envisioned. The two pictures show the results. The only thing I am concerned about is that the welding was not as good as I had originally though and maybe the curved area of the exhaust port should have had a little more metal added to it. It may be OK, but I would like an opinion or two.
Originally posted by TownsendsFJR1300 View PostShort of a new block, looks really good! That won't leak like before.
Does Yamaha call for any sealer or just the gasket?
If the gasket has some sort of sticky film in that area, I don't think I'd put additional sealer on it. That may hamper the sealing properties of the seal itself.
Any place, the gasket is just gasket material(no film) I would think some Yamabond won't hurt anything.
Anything (sealer) near where the exhaust is blowing out has to hold up to very high temps...As good as your block looks now, I think your fine without anything additional..
Originally posted by rpambrun View PostI went out to Gore Marina tp pick up my new tank and one of the brothers did some more welding on the PH. I filed it down and it does look a lot better than before I had them do that.
ÂÂÂÂ
