Which fuel line diameter is recommended for a saltwater 130hp? 3/8 or 5/16? Thank you for your help.
Fuel line diameter for saltwater 130hp: 3/8 or 5/16
Originally posted by david123 View PostI am not sure. Existing installation has a: 5/16 (8mn) line from tank to water separator filter, and a 3/16 line to the outboard. Should the lines have tge same diameter?
If the tank to fuel filter is 5/16th's, you can keep it the same...
Make sure you get MARINE RATED FUEL LINE.
It does make a difference with ethanol breaking down the innards of some regular fuel line...
ÂÂÂÂÂ
