Ok, I have a 20 inch transom but the 200 hp outboard is 25 inches. I'm fabricating an aluminum bracket to raise the motor. I've read and some suggested that when motor is trimmed all the way down, the cavitation should be level with the keel. And some say 1/2 inch, or 1 inch above keel. Before I start cutting up the 3/8 aluminum plate and start welding, I really appreciate all your input as what the boat manufacturers are doing, and your personal take. The 19' grady white is a bit heavy so I'm leaning on raising the motor 1 inch above keel. Any advice would be greatly appreciated. Thank you.
raising up the outboard
Hi, I have played with raising the motor , just as you are doing. I read that the cavation plate should be even with the bottom, so that is what I did. I had very good results. I think that higher than that is mostly for racing and high performance applications. I hope this helps, Dennis
I am running a 1997 80 hp on a 20' pontoon. I thought I would raise the prop up (engine) between the logs to avoid hitting bottom which is a recurring problem here in Florida. Well it worked but, when running towards full open for about 5 minutes or more the over temp alarm went off! Aparently she was sucking too much air. Only fix was to lower the engine. I found that the cavitaion plate needed to be level with the bottom of the logs.
