I've used this twice within the last on two engines that hadn't been run in YEARS (customers).
One was a high end, Echo chain saw, the other a cheaper B&S 7 HP pressure washer engine.
After cleaning carbs on both(varnished up), neither would start (or even cough). Even a spritz of starting fluid or pre-mix, nothing.
For S&G's, on the chain saw I put one squirt of two stroke oil down the cylinder. As most know, this usually results in a slightly higher compression (PSI) helping the rings to seals better.
The Echo, after doing this, cranked right up, (smoked a bit, obviously) and began to run normally. A heavy dose of RF and it was running like new..
The other day, the 7 HP engine, same thing. Squirted some oil down the plug hole, a couple of pulls, it kicked, smoked and than ran great!!!..
Both started fine , got tuned, ran tops and was put back into service after testing.
I suspect the little bit of extra compression was enough to suck more fuel into the engine and help them to both start. Something to remember when trying to start an engine that's been sitting and all else (carb cleaned, has spark, etc) has been done... Good for the engine too, some extra lube where there hasn't been any for quite awhile (in excess of TWO years).
