I have a 2001 LX250TXRZ with 120psi on al cylinders except bottom on port side which is 65psi. Motor runs fine. I have never done a leak down test on a 2 stroke. I assume piston needs to be at TDC for the test. Should all other plugs be left in except adjacent plug and how much air pressure should I use? Hopefully I have a bad head gasket and do not need a rebuild.
Low compression in 1 cylinder
I would bore scope to look at top of piston and cylinder wall, or just pull the head to see
if you do get a leak down tester it will have info on PSI of air.
make sure you do not let the device you use to hold flywheel from moving hit you when you put pressure in cylinder
Is that advise from personal experience? I could see me doing that. I was thinking if I left most of the plugs in and did not use too much pressure motor would not rotate. I am not looking for a percent of leak down, just hoping I can determine if it is a bad head gasket.
No not from what I have done, but have read about people getting hit when it moves
how do you plan on putting air into the cylinder?
I guess you have the compression tester with a quick connect you can rig up to air hose.
put some low amount of pressure and listen for the leaks
raise as need
Originally posted by oldcobia View PostIs that advise from personal experience? I could see me doing that. I was thinking if I left most of the plugs in and did not use too much pressure motor would not rotate. I am not looking for a percent of leak down, just hoping I can determine if it is a bad head gasket.
Could be a head gasket or a leak in the head (corrosion) itself.
https://www.boats.net/catalog/yamaha...er-crankcase-2
.Last edited by TownsendsFJR1300; 05-31-2018, 04:12 PM.Scott
