Hello to all, I just acquired a 1993 85 HP Yamaha and as we took it out for a spin it started bogging down and would not stay running. So once I got it out of the water I pulled the plugs and it was milky inside. I removed the side plate, broke one stud and removed the cover. Once i removed the inside exhaust plate I found a small hole on top so I ordered the parts and gaskets. I then sprayed lubricant through the crabs and pistons.
?What else would you all recommended me to do? The parts are going to take a few days to get here and I don't want rust to form on the pistons or crank. I'm going to buy a can of fogging oil this morning and spray it again.
?Should I do this everyday until I run it again and how should I run it once I get it going again?
Thanks,
Al
Thanks,
Al
