I have a 2003 F115 that started losing rpm. Boat runs fine at idle and will rev up in neutral but the rpm at full throttle went down to 3500 under load. I took out the vst and the fuel in it looked pretty clean, no water. Filter looked ok but I replaced it anyway. Took it for a test drive only to find out the out the rpm wont reach 3000 now. Could this be a throttle sensor issue,?? Any suggestions would be most appreciated. Thanks!
2003 f115 won't rev up under load.Help!!
