I have a 2005 50hp four stroke efi tiller. I have been having some water pump/cooling issues and have no gauges hooked to motor(boat came that way). i would like to be able to monitor the water temp/tach/oil press....ect. Do the newer style digital gauges work with a 2005 or do i need an analog water temp gauge? I thought this motor would have a buzzer but it doesn't go off even without water pumping. Not sure why. Maybe need a new temp sensor? Buzzer does sound when you turn the key on so i don't think the buzzer is broken.
digital gauges
Originally posted by rodbolt17 View Postif its a US market EFI you can use the digital package.
the buzzer should NOT sound at key on.
something else is wrong.
Originally posted by liliepad1 View PostJust because its not peeing don't mean its not pumping water . why do u think your are having a cooling issue ?
Â
