Recently purchased AB rib, weight is 95 lbs. Total weight with 2 adults, fuel, etc around 450 lbs. Cannot get to plane with 2 people. Current prop is 9X9. Dealer says needs more pitch. Appreciate thoughts on correct prop.
Prop for 2006/7 Enduro 8
If you really want to have sure about you'll need instead of guess get a tach (even a cheap/chinese/tiny inductive tach) and depending of RPM's/REV's at WOT you'll where to go (High or Low pitch Prop)
Your motor should work close to 5500 rpm at WOT
ÂÂÂÂÂÂÂ
