Recently purchased a boat with C85 Yamaha, I replaced plugs, and fuel filter. I also decarbed. It seems to be a fuel problem as a touch of starting fluid will start it. Not sure where to go now, except maybe pulling carbs. It seems to run fine when I get it started.
96 C85 Hard Starting
Funny thing, I didn't know I had a fast idle lever, where exactly is it?
Doh! Never mind, I found it with some searching. Hopefully that will help alot. At least I will be giving it a fair chance to start now. When the rain stops I will give it a try. ThanksLast edited by fuzzymaster; 02-03-2014, 01:24 PM.
Experiment with slight changes in your starting procedure until you hit the "right" combination. On my C90 Yamaha I pump the prime until hard, leave my throttle lever closed/down position, then I crank on motor for about 3 or 4 seconds, let up on it for a couple of seconds and then resume cranking and she'll start right up every time....after initial warm-up/running the starting is instantaneous every time....
manualy advancing the throttle on a C85 will allow more fuel, more air AND advances ign timing.
the C90 has prime start.
based on engine and prime start thermal device temp it will automatically advance ign timing and add fuel as nessasary.
on a prime start engine advancing the throttle may make cold starts hard to impossible.
the CORRECT starting procedure MUST be used or it may be difficult to impossible to start cold.
starting fluid can and will damage pistons.
Tried to start it today, no go. Definitely flooded. I tried choke, throttle lever small amount, and never fired. I'll try no choke next time, or small amount after turning over.Last edited by fuzzymaster; 02-04-2014, 01:04 PM.
If it's flooded then turn off the choke...the last thing you need is a richer mixture...and open the throttle lever to provide more air....Sounds like your spark plugs may be wet/fuel fouled caused by this very rich start-up mixture...how do your plugs look?....Keep working on this and you'll get it down pat and she'll crank right up every time...good luck!
If the fuel pump has a rip,hole or tear in the diaphragm it can cause raw fuel to get sucked directly into the crank area, bypassing the carbs/choke/induction system, and causing a very rich mixture. It's an easy check and cheap($50) and easy to replace. I guess you have no way of knowing if fuel pump has ever been replaced?...
