My assumption. Am I correct?
  • My assumption. Am I correct?
    Let's say I am riding along in my boat with F150 at about 5000 rpm. Someone removes a battery cable from active battery. Will the motor shut off immediately? I assume it will.
    I would think it would fry things just like a bad connection at battery
      A motor with a CDI ignition system will continue to run just fine. My Mercury carbureted two stroke did not even have a battery.
      A motor with a battery/coil ignition system will also continue to run. But if you use the trim switch it will die.
        it shuts down.
        you just lost the circuits for the fuel,ign and control.
