I've been rebuilding a 2004 F60 - and got as far as mounting it on my 1987 Whaler 15. Once it was mounted, I went to insert the steering cable (Teleflex) through the tilt tube. It wouldn't go - kept getting jammed. The boat is in storage - but I went to visit it today. While there, I looked through the tilt tube - and it looks like it is bent. That would explain why the steering cable won't go through. I'm not sure why it's bent - as I got the engine used. In fact, the reason for the rebuild (and why I got it) was because the upper engine mount failed - and the owner didn't want to deal with the work to remove the block to replace these. Worked for me - but might also explain the bent tube...maybe.
Regardless, it appears to be bent. The replacement part is 63D-43131-01-00. But, I see on eBay a part from a 1996 F50 that is 63D-43131-00-00. I'd rather go used to save some $$$.
Is this just a superceded part? Would it work? What does that third set of digits mean? Does someone have the secret decoder ring for the meaning of the different sets of numbers?
Thanks in advance!
Thanks in advance!
