yamaha dual 704 control cable installation instructions
  • yamaha dual 704 control cable installation instructions
    I need instructions. I have the shifter cable I purchased from boats.net but I'm not sure how to separate the binnacle halves to get to the cables.
    the dual binnacle is two seperate single 704 control boxes,, they are held together by 3 screws,, two at the top and 1 at the bottom, one screw comes in from the right at the top and one comes in from the left at the top, you may have to remove the mounting brackets at the top, once they are seperated then remove the plastic cover then you can address the cables..
      insert the knife between the second and 3rd rib.
      slowly move the knife.
        Sounds like someone has be hitting the sauce tonight
        Watch that drinking and posting
