What could the design engineers have done to facilitate greater water flow through the thermostats housing area to prevent or mitigate the build up of crap?
Somebody Explain this to me Re: T-Stats Question
Originally posted by boscoe99 View PostWhat could the design engineers have done to facilitate greater water flow through the thermostats housing area to prevent or mitigate the build up of crap?
- as from some exhaust covers -
then "tee" those into the flush hose.
I have fantasized about drilling the thermo housing and pressing in a hose barb
Do that and you likely wouldn't even have to run the engine, flush port ONLY..
I'm not sure if the LU would get a good rinse NOT running, but plumbing into the rest of the system is great!Last edited by TownsendsFJR1300; 03-09-2018, 02:04 PM.Scott
it's a saltwater engine. There has to be a way to do it.
Perhaps adding what I'd call a "flush valve".
Such a valve could be sandwiched (bolted on) in between the T-stat and T-stat bore.
There seems to be enough room under the hood for this.
Then, have some kind of lever that protrudes through the base of the cowling.
Pull down, and the T-stat flush valve opens to allow water to pass.
Push up, and the flush valve closes.
Grady-White 330 Express
Originally posted by pstephens46 View Post
The thermostat "frame" appears to be copper or brass. What if that was covered in some sort of nitrile coating. Alodine and zinc chromate primer help. Would that prevent the battery effect by reducing the chance for conduction?
I was thinking of a large diameter hose that could run to a port on that housing. On the engine side of the thermostat. So flush water would flush backwards from the top and down instead of from the bottom and up. Half inch ID at least.
The current flush hose is too small and too long IMO to really be effective. Water being introduced into the base of the block is being lost out below while at the same time it is trying to fill and flush the block.
On the other hand, I dare guess that the vast majority either don't flush or don't need to flush (fresh water users) so maybe Yamaha things "why bother improving the system"?
I'm stocked up on Alodine and zinc primer. I don't know if any of these flush ideas will work. Most of this residual salt crud should be somewhat diluted by running in the saltwater itself. At least moved around some. I removed my excess with a paper towel. No scraping needed. It still chewed a hole by what I assume to be galvanic corrosion.
I'm thinking of removing the cover and stat just to see how much fresh water will flow out at idle, etc.
Originally posted by pstephens46 View PostI'm stocked up on Alodine and zinc primer. I don't know if any of these flush ideas will work. Most of this residual salt crud should be somewhat diluted by running in the saltwater itself. At least moved around some. I removed my excess with a paper towel. No scraping needed. It still chewed a hole by what I assume to be galvanic corrosion.
Also, use just the garden hose fitting if you don't mind with the engine not running so we can see how much water flows out. Given the small diameter of the garden flush hose I can't see it being a whole lot.
Do that and let us know please.
I have a feeling boscoe hit on the problem.
with the flush hose so small and trying to fill the block with the water dumping out as you fill it, it may never fill completely.
with that stat area being the highest point, it may just never get any water up there.
just a pocket of air that has no where to go
it may never fill completely.with that stat area being the highest point, it may just never get any water up there.just a pocket of air that has no where to go
>>> Yes exactly! This supports the idea of drilling a small hole or two in the face of the T-Stat to allow air and some water to pass. Two small holes in the T-Stat probably won't affect engine operating temperature. At 160 degrees and above, the T-Stat will be wide open anyway. It's at IDLE that we're trying to accomplish flow rate to rise salt out. I never thought of an air pocket developing but that makes perfect sense. It's at the highest point of the engine. Kinda like the last scene of the Perfect Storm when the boat was upside down.
If air could be expelled, at least SOME freshwater would make it up to the highest T-stat bore (with muffs on and engine running). Thoughts?Grady-White 330 Express
The Yamaha thermostat is constructed with small bleeder vents to allow air to pass, even when the thermostat is shut tight cold.
Look at pstephens video posted today, you will clearly see the flush water jetting out of those bleeders.
Â
