My 2004 F115 is sputtering or surging when accelerating and not getting above 2500 to 3500 RPMs. This has been an ongoing problem, and intermittent in that sometimes the engine runs fine. After the second trip to the shop, it has started again and is getting progressively worse.
I have had the following work done on the engine:
-cleaned fuel system, new plugs, cleaned vapor separator, new fuel filters, new injectors, new fuel, installed addition fuel water separator - engine ran fine for a few months then same problem
-back to shop for cleaned fuel system including vapor separator, new injectors - engine ran fine for several months then same problem
-back to different shop which found several cylinders not carrying a load, dirty injectors, some metal in VST because of fuel pump coming apart - the fix was replacing fuel pump, pump dampner, fuel filters, gasket, VST bottom, plugs, and re-install injectors after cleaning and flow testing. Engine ran fine for several months but has started surging, running rough like missing cylinders again and has become progressively worse only getting up to 2800 rpms recently
Any comments or advice is appreciated as no mechanic I have been to has been able to diagnose and cure the problem. Running out of options short of another expensive trip to a different mechanic.
