I have purchased a 1987 yamaha 70 hp that sat for several years. I have cleaned carbs, put in new plugs, installed new fuel pump, cleaned fuel filter, and replaced water pump. It runs and idles great once i get it cranked, but can be a beast to get it going. To get it to crank, i set it with fast throttle all the way up and choke all way closed, it smokes quite a bit and sounds like it is running on two cylinders when it finally hits, then gradually over a minute or two smooths out and will idle perfectly. rIf i cut if off it will restart immediately. Let it sit an hour or two and have the same problem all over again.By the way, compression check shows 130, 130, 125 on cylinders. All suggestions appreciated!
really hard cold start
Originally posted by panasonic View PostDo you have a manual for the engine? Does it run well after you get it going?
Please provide the engine data plate information so we know exactly what engine you have.
As noted above, all three carbs have a simple choke plate for cold start up.
http://www.boats.net/parts/search/Ya...TOR/parts.htmlScott
Originally posted by rodbolt17 View Postwatch the choke plates with the air box off. make sure all 3 close correctly.
dude google some operational parts of a carb. the choke on that system bypasses most everything.now if the choke plates wont close AND stay closed when cranking no extra fuel for cold start is avalible and guess what? it wont start cold. have you tried starting it with the manual choke?
I am thinking he may be flooding it due to all of the smoke at start up.
needs some air as well as fuel to fire properly
have you tried checking spark to make sure all is good when it is not starting up.
spraying some fuel mix into the carb throats at a cold start to see if it will fire up might help determine if the problem is lack of enough fuel
If what you are doing is not working try something different. For example, don't raise the fast idle lever and see what happens. Maybe try the fast idle lever just half way up and see what happens.
Try applying the choke for only a moment when the motor is first cranked and then remove the choke and see what happens. You might stumbled upon a procedure that works.
I agree with 99yam. Sounds like it might be flooding out and not starting. The smoke, the motor not running well at first but then clearing up over time, sounds like an excessively rich condition at start up.
my older carbed engines had almost a ritual required before they would start. Like my old Johnson was fuel bulb till hard, pump the throttle to WOT 3 times, Turn key for 7 seconds, tap choke twice while engine is turning, stop turning key key, pump the throttle again, Turn key with no choke and hold until start (normally was 3-5 seconds)
you just need to figure out the ritual.
Originally posted by JerEazy2 View Postmy older carbed engines had almost a ritual required before they would start. Like my old Johnson was fuel bulb till hard, pump the throttle to WOT 3 times, Turn key for 7 seconds, tap choke twice while engine is turning, stop turning key key, pump the throttle again, Turn key with no choke and hold until start (normally was 3-5 seconds)
In my opinion doing it on an old 1987 70 2 stroke is not going to do much to add more fuel to a cold motor
and I am not sure if it helped on your old johnson, because I have no clue if it had anything to to dump more fuel eitherLast edited by 99yam40; 02-23-2018, 01:30 PM.
Originally posted by boscoe99 View PostIf what you are doing is not working try something different. For example, don't raise the fast idle lever and see what happens. Maybe try the fast idle lever just half way up and see what happens.
Pumping(moving) the throttle back and forth only helps if there is something in the system that will shoot extra fuel into the throat/intake (like an accelerator pump on older model carbed automobiles).
We all know engines are more fickle than women. sometimes they just need some lovin.
Originally posted by medicineman View Post
I have tried many ways, but that is the only way i can seem to get it cranked. I am thinking of opening fuel screw about 1/4 turn on each carb as i have it set at the 1 5/8 turn manual calls for now. if that does not help i am wondering if i need to splurge for 3 carb kits as all i did was open these up and clean them. very basic design (about like a briggs and stratton) and besides a little residue looked good so i just cleaned and reassembled. Like i said earlier, unless i missed a passage in carb body, i feel i got the jets opened up fine.
Often, these jets have orifices that go sideways and simply looking thru one end won't cut it...
Each jet should be pulled, initially check to see if light can be seen thru it, then cleaned.
You'd be surprised how much varnish can build up in those very, very small holes..Scott
ÂÂÂÂÂÂÂÂÂ
