digital fuel gauge and analoge gauges
Originally posted by jasoncallej View PostI don't know if you can tell me for what is the use of the red wire I think that the green is tach signal am I right?. Thanks
I was refering to the other dagram wher there is the 4 pin socket. The pink is for trim but the other 3 wires do it have any other use like temp oil or no. Thanks
Does the yamaha need a full charged battery to start or I massed up any wire? I tride to start the outboard and wount start up I know that the battery was not full charged infact after a few cranking it was dead but I know too that I have attached the wire in the socket of the trim/oil harnes wrong if it is trim/oil, harnes as the colors are black/red/blue/white and it is conectet from a 4 pin pluge to the digital module where it conects to the gaugesLast edited by jasoncallej; 12-22-2013, 11:16 AM.
Yes it is a module that gets curent from the ignition and a harnes from the motor and it can conect a no of 3 digital gauges I try to find a picture of it and post it
Originally posted by jasoncallej View PostYes it is a module that gets curent from the ignition and a harnes from the motor and it can conect a no of 3 digital gauges I try to find a picture of it and post it
If what I am assuming is correct, how did we go from analog needle and dial gauges to digital gauges?
Is this what you are now talking about?
Command Link® Single Engine Round Two Gauge Kit from Yamaha Marine Rigging & Parts this is like the sett that I haveAttached Files
I am using a side mount control box and I have tride to eliminate the smal reduser from 6 pin to 4 pin that conects to the ecm and I think that is where I have created the problem tomorow I will chech if there are any fuses and will retry to start the engine. And yes I know that I invent problems
Originally posted by jasoncallej View PostI am using a side mount control box and I have tride to eliminate the smal reduser from 6 pin to 4 pin that conects to the ecm and I think that is where I have created the problem tomorow I will chech if there are any fuses and will retry to start the engine. And yes I know that I invent problems
Why would you try and eliminate the 6 pin to 4 pin reducer? The gauges won't work without it. It contains an end line resistor that is needed for the gauge system to function.
The gauges should not affect the starting of the motor.
ÂÂÂÂÂÂÂÂÂ
