2008 40HP Yamaha 4stroke water in oil
  • 2008 40HP Yamaha 4stroke water in oil
    Just was wondering if anyone has experienced water in the oil? I think it might just be condensation, any thoughts.
    Also, we are getting water vapor and some spiting of water out of upper and middle ports in the picture I attached, is this normal. Thanks
    Not normal to have water in your oil.
    Milky colored oil or just condensation drops ?
    Not sure about the water spray out the ports,
    guessing that's OK, most everything goes out thru the prop when up & running.
    Might check the water pump, might have a leak there somehow.
    Lower (bottom) hole is your oil drain plug, right?
