Attempting to remove trim unit to facilitate corrosion clean-up and trim motor replacement. The upper shock pin appears to be corroded in place. Tried using a c-clamp to apply pressure after soaking with liquid wrench to no avail. Any thoughts on how to solve this problem?
2003 F90TLRB PTT unit removal
Thanks for the reply boscoe99. Yes, I've done all that you suggest including a punch and a BFH. Unfortunately, the circlip end of the pin is inside the swivel bracket which doesn't allow a direct line to drive the pin out. I tried using a long punch, but the angle was too great to be successful.
remove the circlip.
drill and tap the pin, I use 3/8ths x16.
insert a piece of all thread and a large socket.
use the socket and a nut as a removal tool with the aid of an oxy/acetylyne wrench.
Thanks rodbolt, sounds like a good plan. I'll give that a try later on this week when it warms up a little.
Pat
ÂÂÂÂÂÂÂ
