1997 80hp runs but cuts out after a few minutes
  • 1997 80hp runs but cuts out after a few minutes
    I used some carb spray and it ran a little longer but still cut out. Does it have something to do with my Fuel Filter or Battery? Or could it be something with my Carb or Choke? Any Info / Tips would be greatly appreciated!!!
    have you thought about checking the fuel pump,primer bulb, and lines?
    see if pumping the primer bulb helps keeping it running
